Connecting bath waste
1 Apr 2013
Norwich
Quick question, is using a flexi pipe from bath waste to main waste ok? Also should I ditch the factory gaskets and use plumbers mate instead? Please see pics.
And is the pipe ok on a 45 degrees level or should it have a slant?
Slight fall away from the Bath to drain point, be careful not to disturb the joint on the Boss too much, it may leak!
Flexi's best avoided, crud will collect in the ribs.
Supplied Gaskets should be ok.
Good point
So this is the kit I'm using. I take it thats all I need from the bath ready to be linked to the main waste?
