connecting floodlight to a socket
28 Mar 2011
Conwy
Afternoon all
Looking for a bit of reassurance, mainly.
On Monday I installed a 30w Lap floodlight on the rear wall of our property. Initially I was going to power it by breaking into the lighting circuit in the loft, but it would have meant taking up loft boards to access the cables, so a bit fiddly and time consuming. Last year whilst refurbing the bathroom I terminated the cable from the now-removed electric shower in a double socket in the loft, so I decided to put a plug on the end of the floodlight cable and use the socket instead. The socket is on a 32a MCB, and I'd already connected the supply and load sides of the floodlight in a 13 amp FCU before I decided to use a plug. I thought that maybe I needed a lower rated fuse somewhere in the circuit ( although its not a high powered floodlight), so I changed the 13 amp fuse in the plug to a 5 amp. Everything is working so far, and I just wondered whether there's anything I should have done differently ( other than not being lazy and using the lighting circuit instead).
Many thanks
I would say powering the outside light from a socket circuit is better than a lighting circuit, as should any water get in, tripping the RCBO will not plunge one into darkness, and it is easy to unplug it.
Also, I have simply plugged in a socket adaptor,
and you can switch it on/off with your phone. That's what I do with outside lights, makes it so easy to turn on lights before I even leave the car.
I, too, have my outside lights exactly like that, but via Alexa. One lantern style, illuminating the drive, dusk until 11pm, and a couple of larger lights. Which means I can turn them on via voice command, the PC, or using the phone app.
Back in the mid 80s we bought a special noise-operated bulb for the dining room of our first house. You screwed it into the bayonet fitting like a normal bulb, but turned on the light by clapping your hands then turned it off the same way. Trouble was that the dog decided we were playing a game for his benefit, and he would bark furiously when we clapped our hands, so the light fitting had to go.
