I am solving a garden flooding problem by installing a dirty water pump which I intend to connect to a weatherproof outdoor socket.
My problem is that the pump has an RCD fitted and I dont think any outdoor sockets will take this and still be waterproof (ie lid won't close).
I wanted to remove the RCD and fit a 13A plug with an RCD fitted elsewhere (perhaps on the socket), however the pump instructions say that if the cable is damaged then the pump should be scrapped.
I want this to be a safe permanent fitting. Any suggestions for the best route to follow?
Jim
Edit - I've said the pump is fitted with an RCD plug - it is actually an RCCB is this the same thing?
Jim
