Connecting Two Flexi Pipes? Isolation Valve?
1 Aug 2018
Hi all
I'm in the process of replacing a basin monobloc tap with another.
The previous had copper pipe going to the tap which connected to an isolation valve and then to a Flexi pipe.
The new unit has Flexi pipe from the tap which I need to connect to another piece of Flexi pipe. What is the best way of connecting? Would an isolation valve work or is there something with two flat ends that would work better?
Are you trying to connect two braided flexible hoses together ? Why can't the flexible hose that comes with the tap connect directly to the supply pipework ,via an isolation valve and tap tail adaptor ?
If you want to do a proper job ,extend the copper supply pipes and fit an isolation valve on each. You can then fit into each isolation valve ,a tap tail adapter ( which has a flat mating surface ). Your taps Flexi hose screws directly onto the tap tail adapter.
As said extend the copper or if you don`t want to do that then buy longer flexi`s. Wouldn`t join two myself.
Thanks all
I'll look into this - would likely have to get someone in as I've no experience extending copper piping so would be better done by a professional I think.
Unfortunately previous copper tails won't fit the new tap, however, I could possibly buy some (like these)?
https://www.bes.co.uk/copper-monobloc-tap-tails-m10-x-15mm-19800/
Hard to be sure ,but it looks like a radiator tail in between iso and flexible hose. They do have a flat surface ,if that's what it is. No need for the PTFE tape though.
