- Joined
- 4 Jan 2012
- Messages
- 354
- Reaction score
- 7
- Country
Hi guys - me again!
Being a DIY'er Im doing ok thanks to you all. Im now at the kitchen waste stage and was wondering - whats the best method to connect to the solvent weld elbow as in the picture? Im thinking
www.screwfix.com
and then use the compression stuff to
www.screwfix.com
Or would you go a solvent weld T so its slightly roddable into a solvent to compression coupler?
Thanks!
FloPlast WC27 Universal Compression Waste Conversion Bend 90° 40mm - Screwfix
Order online at Screwfix.com. 90° Conversion Bend, socket to spigot. Made from polypropylene, this quick and easy to install waste system incorporates a compression outlet that accepts plastic and copper pipes. No solvent welding required. It is recommended that externally installed...
FloPlast Double Bowl Sink Trap Kit White 40mm - Screwfix
Order online at Screwfix.com. Constructed from high temperature polypropylene with compression outlets. FREE next day delivery available, free collection in 1 minute.
Thanks!
