Hi all,
Can anyone advise on on the following 2 quick questions please.
I have a conservatory with 3 double sockets off a 5 amp spur and i am planning on putting 2 x 1250 watt radiant heat electric radiators on the outside wall.
I need a further double socket so first question is.....
1 - Can i just take a feed from the closest double socket ?
and finally,
2 - Can i drop the cable in the cavity between the brick and block work on the dwarf wall of the conservatory, rather than chip out the plaster work on the inside wall ? Is this safe to do ?
Thanks in advance.
rgds,
Sean
and finally,
Thanks in advance.
rgds,
Sean
