- Joined
- 2 Dec 2004
- Messages
- 751
- Reaction score
- 8
- Country
Hi all,
Well we are in the process of having our conservatory constructed. And I now know exactly why a proper extension costs three to four times as much as a conservatory which, having been watching the build, is best described as sh1te.
Anyway i thought id raise some of the more worrying points so that I can go back to the guy if necessary.
First, the amount of packing under the framing on one side is getting up to an inch of packing. On the other side the framing sits nicely on the brickwork. I can see quite alot of expanding foam has been used so far, but I can still get my entire hand under the cill and frame. Can I expect that this will be mortared in properly do you think?
Second, the installer has attached the lean to roof, (35mm poly non supported roof system) and has channelled out the mortar above for the flashing. However the flashing has not yet been installed, id have thought he wouldn't be able to climb on top of this roof so im wondering how on earth he is planning to get up to do the flashing?
Third, on the one side we have a full height wall with a thin row of windows along it. The installer for some reason has had to recess the frame and cill of this thin window row so that it sits accross the cavity of the wall. The external cill therefore does not now overlap the exterior of the wall so the installer has put some lead on and folded it down over the brick work. It looks terrible.
Fourth, we orginally asked for floor and wall insulation. The builder installed 25mm polystyrene sheeting in the floor and then went on to use no wall insulation and he has left only about a 50mm cavity. When questioned, he said he used thermalite blocks on the internal skin so that these fullfill the purpose of insulation. How do thermalite blocks measure up?
Fifth, by no means last. The lean to roof is supposed to be joining up to a flat roof on one side. I know you cant see it and I have no picture yet, but from what hes done so far I cant possibly see how he is going to make this weather proof.
Anyway this is more a rant than anything else. I was just expecting a bit more quality than has been delivered at present. I'll try to upload some pictures soon.
Cheers
Dan
Cheers
Dan
