- Joined
- 12 Jul 2025
- Messages
- 4
- Reaction score
- 0
- Country
I am considering a loft conversion in my 70s built end of terrace property. It has a low pitched tiled roof, spanning 9M with a 2.6M ridge height above the 2"x4" rafters and purlins supported on vertical struts at approximately mid span with a horizontal brace between the purlins at approximately 2M spacing, and 1,5M high which would obviously need removal. I am concerned about trying to avoid increasing the depth of the 2"x4" ceiling joists as this would impact on the useable space available. Is there a way round this? the usable space between the purlins is 3.8M. The main issue apart from useable space in the loft, is the staircase which would need a right angle turn at the 9th/10th step to allow the top step to more or less coincide with the ridgeline, but also allow the main staircase to be located in the existing single bedroom below and still have room for a door into that room, albeit a 695mm door, not a 750mm door. any increase in height will create a similar increase in the length of the flight of stairs, (which I have already calculated using the maximum pitch of 42º). Increasing the number of steps after the landing will have a detrimental effect on ceiling height in that location in the adjoining room ( I can accept three steps but not four) and the landing would already require a two-step arrangement rather than a flat landing. Because this is a one bedroom flat in a conservation area, I am already concerned about getting planning permission, including permission for velux windows which may only be allowed, if at all, to the rear of the property. I am also hoping they will allow a window in the end wall as it is an end of terrace property, but those are concerns to be addressed at a later stage.
Additional information:
The main staircase will run parallel with the ridge line and then turn against the party wall for the last three steps. One last point, is a door required at the top of the stairs before entering the loft bedroom and if so, being at right angles to the last flight of steps, does the 400mm distance from the top of the stairs rule still apply?
(Which is another potential reason for restricting the top flight of stairs to three not four as it would push the door too far away from the centreline and meaning it would potentially have to have an angled cutout at the top which I don't want.) The walls appear to be prefabricated "egg box" style construction of only about 75mm thickness with extra thick plasterboard bonded to a cardboard matrix internally with approximately 2"x2" timber verticals at 400~500mm centres. The wall that the main part of the staircase will run alongside of, is about 500mm off the approximate centreline of the property.
