What is the best way to construct a ground floor stud wall on block and beam that will have, insulation, UFH pipes and a 70mm screed on top? If i fix the sole plate to the block & beam, there will then be 100/150mm of insulation plus a 70mm screed on top. How do you prevent screed from filing between the stud cavity?
All other ground floor are block built walls, this is a 90 degree stud wall within a room.
