- Joined
- 13 Aug 2007
- Messages
- 11
- Reaction score
- 0
- Country
I am going to make some built in wardrobes. I am going to make them out of sheet material.
I am a liitle unsure to the construction, i was under the impression that i should butt joint the top and bottom panels to the side panels with the side panels overlapping (but not portruding) the top and bottom panels, screwed through the side panels (clearance hole) into the top and bottom panels (piolt holes). Then the back panel overlapping (but not protruding) the side panels, top panel, and bottom panel, screwed through the back into the sides top and baottom panels.
Is this right?
I hope you can help
Is this right?
I hope you can help
