I have a 9.5Kw shower installed but the fuse in my consumer box to the shower is a 32Amp I would like to change the amp to a 45A fuse (which is recommened by the shower manufacturer)
however my question is
I have an Ln6180 fuse box that I suspect is only an 80Amp rated, The fuses in my box read 32A,6A,16A,32A,32A can I take out the 32A fuse that is assigned to the shower unit and replace it with the 45A ? so it will read 45A,6A,16A,32A,32A or will this be overloading? as i read it at the moment I am already overloading at 118A through an 80A CU or am I wrong?.
or does the rating mean 80A maximum per fuse?
The shower was installed by a professional and he was supposed to come back with the fuse and replace it but never has.
