I have a project where I need to split the existing tails between the meter and the consumer unit so that the tails also feed a switch / fuse to an outdoor building.
To separate the meter tails to supply the existing CU AND new switch/fuse I need to add a pair of Henley blocks. I have it in mind that these should be ok in my flush meter box if I tuck them away in one corner leaving space in case the DNO ever want to put a bigger meter in. I had my doubts whether I am allowed to put any equipment in the meter box so did a quick Google search and found this:
http://www.eonenergy.com/FAQ/New-Connections/Meter-Box-Size.htm
e-on say that a space 500mm x 350mm should be provided for the meter with no consumer equipment in the meter box. This is a bit restrictive in terms of splitting the tails.
My questions are:
Q1. Is it allowable to put Henleys in the meter box?
Q2. If I'm allowed to put Henleys in there, can I also put the switch/fuse in there (leaving as much space as possible for a larger meter).
I am hoping that the space requirements that the DNOs ask for are just to make sure their meter fits and that there is no mandated restriction on fitting consumer equipment. After all, some internal meters are on a shared board with consumers equipment.
Read more: //www.diynot.com/forums/electr...-two-log-cabins.320411/#2373016#ixzz1sgd5ptdw
My questions are:
