Consumer Unit - Fuse Block
3 Apr 2005
I need to wire an Oven. Have 6mm2 cable. And have a cooker socket/switch. The consumer unit has a SPARE fuse slot (two pin style, with wire fuse).
The spare fuse socket in the consumer unit is coloured white/cream. The RED one is used. Is it OK to use the white unit to power a cooker on a radial circuit, the fure wire will be 30amp ?
(the red one actually runs to another smaller consumer unit, located in the kitchen; but this one doesn't have any spare fuse sockets...)
Dan
You need to change the fuse and carrier from white to red.
(5amp to 30amp)
Your best bet is to buy a wylex (or equivilent) 30amp HRC assembly. This will come complete. You can also get 'plug in' mcb's. These maybe used, get one complete with a base.
