Consumer unit
That's very snazzy (hence, I assume, expensive), but does it actually represent much of an advantage - other than to someone who wishes to work in the CU when it is at least partially live?
Its also useful when you are working on a number of circuits and don't have enough lock-offs for all the MCBs, quicker than taking all the lives out the breakers.
I fitted a MG unit for a guy who was an ex NASA engineer, he had researched long and hard and concluded that this was the best on the market, he had suffered from nuisance tripping of RCBOs on his Proteus CU for years, after the MG went in no more nuisance trips
Not sure I'd fit an all RCBO MG unit in domestic... they don't seem to do RCBOs in B type, only C type
Quicker, I'm sure, but can you 'lock' that?
Kind Regards, John
Yep, that certainly happens many times. You quite often find them sat on top of a CU when you go to do an EICR too!
I have a tendency to forget to refit the Neutral bar cover in Schnieder 3ph boards, especially the Square D ones! :evil:
Well not lock it per-see. but once the board cover is back on then you are going to need a tool to get back into it to put it on.
It might not be ideal in a factory maintenance situation where you might have other sparks opening up the board. But in say a commericial re-fit where say offices are being knocked around and theres only one firm of electrical contractors going to be taking the board lid off then its good as locked off
Kind Regards, John
I thought that the whole point of moving the live circuit core from the Breaker into the Earth Bar, was to facilitate the R1 and R2 Earth testing that one is obliged to perform after working on any electrical circuit???
Well not lock it per-see. but once the board cover is back on then you are going to need a tool to get back into it to put it on. ... It might not be ideal in a factory maintenance situation where you might have other sparks opening up the board. But in say a commericial re-fit where say offices are being knocked around and theres only one firm of electrical contractors going to be taking the board lid off then its good as locked off
Fair enough. Certainly better than non-locked MCBs, that's or sure!
Kind Regards, John
We have loads of the TPN boards out in service as well;
but as other s have said there are not so many SPN out there
the top bit is there to isolate the particular MCB RCBO that you are working on.
it switches the comb off to the in side of the MCD RCBO
very handy if you just want to drop out a circuit and replace the cover, so litle fingers dont re energise the circuit you are working on!
Oasis
