Consumer Units
14 Aug 2008
Moray
1st of all let me start of by saying thanks, been reading this forum for sometime now and finding it very helpful. I currently have a fuse box which looks very old and worn, so looking at replacing it with a consumer unit. Between the meter and fuse box is a switch, so can turn power off before it reaches the fuse box. The kitchen is currently on the down stairs ring main. For the consumer unit would I be right in thinking I would need,
Ring Main Up Stairs 32 amp
Ring Main Down Stairs 32 amp
Washer/Dryer in utility room 32 amp
Kitchen Ring 32 amp
Light Up 6 amp
Light Down 6 amp
Cooker/ hob 40 amp
Hope I am on the right track with this.
Russ
Dont even attempt a consumers unit change unless you know what your doing, Get an Electrician in as it's not just a case of swapping old for new! Once the new board is fitted it needs to be tested for safety and the only way to do such test is with suitable calibrated test gear (costs about £500)
You only live once, dont risk loosing it!
Hi Russell,
Sorry but without knowing the characteristics of your circuits, like cable sizes, wether they are in fact ring/radial circuits etc I feel we cannot advise you on the protection needed.
Do you have the 'kit' to test the circuits, and feel capable of using it ?
RCBO's or RCD's might be worth looking into.
Ed
Thought it would of been a case of swapping new for old so will go down the electrician route, cheers
