By using it to feed a known load ( and nothing else ) for a known period of time and then compare change in reading with calculated power used in the load.
Use a fire bar element as a load with an amp meter and volt meter to measure volts and amps into the load during the test. ( Volt meter across supply and not the load, this then includes the small amount of energy in the shunt of the amp meter ).
Take readings ever five minutes as voltage and hence power may vary during the test.
