My understanding for putting control joints in a concrete 'pad' ie one which is on the surface, is because it will be exposed to temperature variations and the joint allows for expansion and contraction. Therefore concrete footings for a wall do not need control joints because they are (of the order of) a metre below the surface and the temperature is assumed to be constant hence minimal expansion or contraction. Hopefully you all say AYE. If so that answers my first question.
As I am a slow worker I anticipate that I will not be able to lay the complete footing in one day. Do I put in a (control) joint when I lay the second part or just go right up to the (probably) already cured concrete? The footing is 11.5 metres long and then has a right angle for another 4.5 metres. Depth of footing 225mm, width 300mm.
Why are control joints put in retaining or free standing walls? Is it for the same reason as the concrete pads? If so why do house walls not have control joints?
All answers gratefully received I am pouring tomorrow!!
Cheers
Cheers
