I'm hoping to change an existing 1-gang light switch to a 2-gang switch controlling both the existing light and a mains powered floor lamp - will try to explain how, and would welcome any opinions/advice!
Below the light-switch is a 2gang ring-main socket. If I run a 3A fused spur to a single socket for the floor lamp, then 1.5mm twin core cable back to the light switch I think it should be fine to wire into the second gang alongside the standard light switch, correct?
My only concern is that somebody in the future may not figure the spur is wired into a standard light switch and swap out the 3A fuse for a 13A to power some appliance. Is this a genuine concern?
I realise I have a few options: I could cut out a 2nd hole or extend the hole for a 20A rated switch, but really had hoped to use a simple 2g faceplate in style with the room's other fittings - which is also the reason I'm avoiding modular options.
I'm also considering cutting the plug off the light and wiring it into the lighting circuit, but then it's not easily movable if the need arises. Perhaps still the best solution, I don't know anymore, my mind seems to go round in circles!
