scatmanjohn said:You don't have to cut the pipe, just undo the two fittings connecting the pipes and fasten the cap ends on to the nut & olive that is left on the pipe.
Don't worry the boiler will soon shut down if there is no flow around the system.
Do you know how to drain the water out of the system first.
Yes I used wrong wording, I was just going to undo those compression joints and cap them and yes I can drain system... do you think two of those pipes should be returned and he has linked wrong ones?
I am going to lift some boards tomorrow and see what pipes are heading where... If it does not work I will do a drawing..
I guess pipes are old bath supply, combi supply and return, mains feed to upstairs loft, supply of cold water to old cylinder, what am i missing ???
