Converting 22mm to 15mm pushfit fitting
5 Oct 2008
Essex
I'm installing a new shower pump which has JG speedfit fittings. I need something that will convert 22mm male pushfit to a 15mm male pushfit fitting so I can finish plumbing it in. I ordered a 22mm X 15mm reducer thinking that this would reduce 22mm pipe down to 15mm, but it had a 22mm male end converting it to a 15mm pushfit fitting (the exact opposite of what I want).
Could anyone suggest something appropriate please, as I can't find anything when googling?
Thanks.
if you have a 22 male fitting and 15 male fitting use the coupler in the middle.
My shower pump is female speedfit.
The hoses that come with it are 15mm male to female.
My pipes are 3/4 screw in things.
I converted these to 22mm speedfit male with these...
http://www.fwb.co.uk/mall/productpage.cfm/FWBGroup/217WBA
Hoping to convert them to 15mm with these...
http://www.fwb.co.uk/mall/productpage.cfm/FWBGroup/217WJA
Which as I mentioned actually converted 15mm male to 22mm male, so were wrong.
And so if I buy the 22 to 15 reducing couplers, I end up with female speedfit to female speedfit connections, so what is the best way to connect this?
Or should I just send everything back and take a different approach?
