    Dismiss Notice
Converting phone extension socket to master for PBX extensio
Discussion in 'Alarms, CCTV & Telephones' started by Speakercon, 5 Oct 2014.
  1. Speakercon
    Speakercon
    4 Sep 2011
    76
    Thanks Received:
    2
    Nottinghamshire
    Country:
    I'm in need of some master phone sockets for use as phone extensions from an analogue PBX.
    I have lots of normal phone sockets, can I convert them to masters by simply adding a 1.8 µF capacitor and 470 kΩ resistor in the way shown in the below diagram using these components?
    Capacitor - http://www.ebay.co.uk/itm/231069607556
    Resistor - http://www.ebay.co.uk/itm/161349300192
    [​IMG]
    Many Thanks
  2. Sponsored Links
  3. Lectrician
    Lectrician
    18 Jul 2004
    8,470
    Thanks Received:
    399
    Devon
    Country:
    Yep, the surge arrestor is not required, known as a PABX master. You will likely get some twits in a bit saying you don't need masters for modern phones. You should still fit masters though, as most standard phones WILL require the ringer.
    • Thanks Thanks x 1
  4. Speakercon
    Speakercon
    4 Sep 2011
    76
    Thanks Received:
    2
    Nottinghamshire
    Country:
    Brilliant thanks! Is the resistor still required?
  5. OwainDIYer
    OwainDIYer
    5 May 2010
    4,534
    Thanks Received:
    694
    Stirlingshire
    Country:
    The resistor is not required on PBX use.
    Its purpose is to provide a circuit even if no phone is plugged in, for line testing.
  6. Speakercon
    Speakercon
    4 Sep 2011
    76
    Thanks Received:
    2
    Nottinghamshire
    Country:
    So would I connect the capacitor from pin 2 too pin 3 on the back of the socket?
    Cheers
  7. OwainDIYer
    OwainDIYer
    5 May 2010
    4,534
    Thanks Received:
    694
    Stirlingshire
    Country:
    yes.
    • Thanks Thanks x 1
  8. Sponsored Links
  9. Lectrician
    Lectrician
    18 Jul 2004
    8,470
    Thanks Received:
    399
    Devon
    Country:
    All PABX master sockets have the resistor and ring cap. Never seen one with just the cap, never tried it without the resistor, but can see it should work.
  10. Speakercon
    Speakercon
    4 Sep 2011
    76
    Thanks Received:
    2
    Nottinghamshire
    Country:
  11. bernardgreen
    bernardgreen
    3 Nov 2006
    24,820
    Thanks Received:
    2,444
    Bedfordshire
    Country:
    The rated voltage and capacitor are correct, provided the quality is OK they should b OK, the leads are intended for PCB and may have to be extended.
    The resistor may be needed on some PAXs as some modern ones do have line testing functions. But on a PAX unless some of the lines are very long adequate testing can be carried out without the resistor.
  12. AlanE
    AlanE
    26 Feb 2004
    2,986
    Thanks Received:
    557
    Essex
    Country:
    True but it would also provide a discharge path for the capacitor if for example the phone was unplugged whilst phone ringing.
  13. Speakercon
    Speakercon
    4 Sep 2011
    76
    Thanks Received:
    2
    Nottinghamshire
    Country:
    Good point, I'll add the resistor its not much extra work!
    Also I assume + would be too pin 2 and - too pin 3?
  14. bernardgreen
    bernardgreen
    3 Nov 2006
    24,820
    Thanks Received:
    2,444
    Bedfordshire
    Country:
    The capacitor must be a non polarised type as in some circumstances the 50 volt polarity can be reversed.
    • Thanks Thanks x 1
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
