I'm looking at a property to convert. At present it has two small rooms in the roof space one at either end of the building each accessed via its own spiral staircase. This leaves a large portion of the roof space unused, at present the this middle part of the building is opened up to the roof.
My plan would be to remove the spiral staircases and extend the floor right the way across.
My question is at present there are two big wooden roof trusses that have tie beam running at a height of approx 1200mm. is it possible to:
A) remove the tie beams to either open up the space entirely allowing me to divide into whatever room sizes I like or
B) At least cut a doorway through the tie beams.
I appreciate that the tie beams are there to stop the roof spreading, I'm just not sure if my plans are feasible or cost effective.
