Hi
I have an old Victorian (circa 100 years old) property which has a downstairs bathroom at the back, which itself has a doorway to a smallish toilet room/WC (that I suspect may originally have been an outside toilet; I don't know). We have resited the toilet to inside the bathroom and are in the process of converting the space freed up into a shower room.
The existing brickwork is only single skin so I need to build a second skin, which I am doing with low density blockwork (the stuff that you can cut with a saw). The problem is that there is not going to be much or any of a cavity between the two skins. I believe the cavity is supposed to provide two functions - one is a thermal barrier (but perhaps only if filled with something) and two is moisture barrier?
Questions I have are:
1 Given that I don't have enough space to play with to allow me to fit something like Celotex, is there anything I can do given that the cavity (such that it is) will be only a few mm wide?
2 Can I (or should I) put some damp proof membrane between the two skins, and if so how would I 'fix' it in place?
By the way, the shower will be ventilated with a fan which vents through the roof which comes on when the light is switched on. Also there will be a fan in the bathroom. Oh, and I have already bought Aquapanel for the plasterboard duties for the wall and ceiling.
Thanks.
Thanks.
