I am looking to fit a new kitchen, and currently looking a a Bosch induction hob and seperate built in single oven. i have had a couple of quotes to move electrics, but split 50/50 as to whether i need a new consumer box. 2 have said i do and 2 have said i dont.
the current wiring is from about 1990, and is in OK condition. i currently have a 32amp cooker connection, which 2 of the sparkies have said they can run the cooker and the hob off, but will move it to the new location. the other 2 have said i cant and i need a new consumer box as they dont make the trip switches any more.
the hob is 4.6Kw and the Oven is 3.5KW. The two electricians who have said i can run it off a two point cooker circuit have said these will be ok on a 30amp circuit. is this right?
the reason i question, is because two other electricians have said i should change the consumer unit, but im not sure if they just want money for old rope - the 2nd reason is that on one of the cooker reviews, the comment from someone says that as the cooker is 3.5Kw that it can pull up to 15amps, which is half of the circuit.
so....my question is, can i put a hob at 4.6kw and an oven at 3.5kw on a 30amp circuit??
Alan
Alan
