Hi All,
We're getting an all-gas range cooker delivered next week to replace a built-in gas oven and gas hob.
Before the range cooker is fitted I will obviously need to remove the old appliances, cut some worktop out and move some cupboards over to accomodate the wider appliance. I'm also fitting a wider hood to suit.
The question is one of disconnection. Assuming that the current hob and cooker have originally been connected properly I guess that at least the hob will have been done with copper and the oven will have a hose. This should have an in-line shutoff valve as the installation is quite recent.
Is it legal for me as a DIY'er to disconnect these appliances, remove the appliances and then arrange for a gas safe engineer to re-connect? I will also shut off at the meter cupboard to be 100% until all works have been completed so there will be less chance of leakage through the valve.
or,
does the cooker supply line need to be capped-off as well as the shut off valve and then re-established when the new appliance is comissioned.
or,
