Cooker circuit.
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
Is it feasible to fit a contactor (say 45amp) to control the cooker circuit instead of 45 amp switch plate. I was considering using a gridswitch to power the contactor.
For sake of tidiness. A small switch (on the gridplate) operates a contactor that carries the heavy current
Spose you could if you really want.
You would need a low current supply for the control circuit though.
Would an MK 1 gang 45A DP switch not be just as neat, and a lot less fuss?
or put the switch in a cupboard, not strickly correct but probably alot safer than using a control circuit.
How many 'not strictly corect' in-cupboard isolators have we fitted in the past say 5 years?
My answer - a few.
Not sure if I'd want to fit a 45A+ cooker isolator out of sight tho.
How?
Hiding a switch in a cupboard leaves you with no readily accesible point of isolation, and does not comply with BS7671.
Although it is a little unorthodox, using a contactor and control circuit does.
Thanks to all those posted.
When the kitchen cabinets are £3.5k, worktops £3.0k, appliances another £2.5k, I want things to look right.
The reason for asking about the cooker circuit mainly based on using grid switches being used and fitted within easy reach for sake of isolation and tidyness to control the final (Inaccessible) circuit that will be powering the appliance. Gridswitches will be able to power all appliances except cooker (45 amp). Contactor powered from a gridswitch lets me do that. Furthermore, gridswitches will each have printed signage indicating appliance controlled.
Fair comment.
I have seen this type of arrangement with gridswitches and contactor for the oven and hob, and it does give a very tidy, easy to use solution.
Do you class a switch which operates an all poles contactor as automatic switching then?
BS7671 said:
460-01-01 : A means shall be provided for non-automatic isolation and switching to prevent or remove hazards associated with the electrical installation or electrically powered equipmen and machines. Such means shall comply with the apropriate requirements of this chapter and of sections 476 and 537
I can't see anything in chapter 46, section 476 or section 537 which precludes the use of a contactor for this purpose. That is why I asked if you class a switch which operates an all poles contactor as automatic switching, as this is the only possible thing I can see for you to mis-interpret.
The dictionary said:
au·to·mat·ic Audio Help /ˌɔtəˈmætɪk/ Pronunciation Key - Show Spelled Pronunciation[aw-tuh-mat-ik] Pronunciation Key - Show IPA Pronunciation
–adjective 1. having the capability of starting, operating, moving, etc., independently: an automatic sprinkler system; an automatic car wash.
2. Physiology. occurring independently of volition, as certain muscular actions; involuntary.
3. done unconsciously or from force of habit; mechanical: an automatic application of the brakes.
4. occurring spontaneously: automatic enthusiasm.
5. (of a firearm, pistol, etc.) utilizing the recoil or part of the force of the explosive to eject the spent cartridge shell, introduce a new cartridge, cock the arm, and fire it repeatedly.
You need to phisically operate a switch to make or break the contactor, so this is non-automatic switching.
