I need to feed a cooker and hob. Plan is 6/10mm feed from ceiling in 50mm plastic duct down through gap between wall & cabinet, through back of cabinet to adjacent wall mounted oven rated switch (no 13A skt).
To feed the hob which is 6 cable metres away (in plastic duct,again with ring and lighting cables), can I just divide from oven switch unit so this switches both or continue on main feed to hobs own wall mounted switch. Only advantage I can see is they are independantly switched.
Anything out of regs. for either arrangement? Thanks.
