cooker hood fitting quote
"Is it a replacement or a new installation?" for starters.... :wink:
Estimate:
Replace metal BS3036 CU (TT) supply.
Full PIR.
Upgrade tails to 25mm.
Install DP RCBOs x 10.
Upgrade main earthing conductor.
Install Main Prot. Bonding.
Lift ustairs laminate flooring.
Lift upstairs floorboards.
Install FCU.
Install fan.
Connect wiring.
Inspect & Test.
Notify.
£1500!!!! :D
Unless of course you could provide the details that have been requested. Bits of string length and all that...
Estimate:
Full PIR.
Install FCU.
Install fan.
Connect wiring.
Inspect & Test.
Notify.
£1500!!!! :D
Ok to install everything cu is roughly 10ft away and there is some covered wires where the extractor can go what other factors would be needed?
And does it have to have a flume to go out side?
Your quote sound very reasonable FingRinal, However I am no spark but should Notify be at the bottom of the list :lol: :lol: :lol:
I think if your not registered you have to notify BEFORE you start.
Others including Domestic Installers ( and possibly Fing ) , can just get on with the job and notify once complete.
One of the advantages of getting someone qualified to do it.
if you want the work done the same day.
a cooker hood needs to be vented through the wall. A core drill can be hired to cut a neat 110mm hole. It is a bit dusy.
a hood that does not extract is useless, except as a kitchen ornament.
:oops: oh, i see, you are only meant to admire it, not switch it on, THAT's where we went wrong then.
But seriously, we have one, its a non ventinging one, NEVER switched it on other than to see does it switch on, we rely on the kitchen extarctor fan.
Kithen fitter said, most are like this now.
as for how much.........
View media item 2443
