When you have cut the cable from that burnt mess strip the cores back to shiny copper strands. Put each cable into a separate terminal block, (one big enough to accept each cable obviously), so they are isolated from each other. Switch on the wall socket and see the result. Hopefully the MCB/RCD will not trip no matter how long it is left switched on.
Alternatively, you can disconnect from the back of the wall socket and check the terminals in there for signs of damage though I don't think you will find any.
All this is in the absence of proper test equipment.
