I will know for next time that it is not the R or D...as you can tell I'm not an electrician. In your opinion the cable in the photograph what size do you think it is?
I'm rather annoyed because the electrician I used was someone I used on a regular basis and if he fitted an incorrect rated cable I will not be happy. The electrician I used a few weeks ago to hard wire some smoke detectors I mentioned to him that we might need a bigger cable and he said not necessarily ill just fit a 42amp breaker????
What's going on, aren't you electricians supposed to be singing from the same hymn sheet....
