Hi all. Had a look at an issue at a friends place,the 32 amp mcb trips but not all the time,it's the cooker circuit,wired in 6mm to an isolator then to the outlet. At the outlet it has 2 flexes connected into it,one for ceramic job and one to cooker. The one to cooker is no bigger than a 1.5mm cable. He says that he can go for weeks with out any problems and then it will trip just the mcb and can't use oven. Oven doesn't look in the best of shape. The oven has the small flex connected into it without being fused down,goes directly into the outlet connected to a 6mm cable covered by a 32 amp breaker. Can any one help me get to bottom of why it trips out only sometimes. Thanks
