Had a new cooker dual fuel fitted yesterday. I did some of the work myself and it seems to work OK but I am now worried that I may have done it wrong.
The power flex coming out of the back of the cooker was about 18 inches too short to reach the existing cooker power supply unit, which is fitted into the wall above the cooker recess.
The fitter who connected the gas up recommended getting round this by using an extra length of cable and a 13-amp junction box, feeding the power cable from the cooker into the box and joining it from there to the existing cooker box with the new cable, which I did.
The cable coming out of the back of the cooker is 2.5mm diameter.
However, the extra cable I have used to go from the junction box to the existing cooker box is 6mm - recommended by the shelf-edge information at my local B&Q as being suitable for fitting cookers.
Will the discreprancy in the cable size between the 2.5mm coming out of the back of the cooker and the 6mm going from the junction box to the cooker unit on the wall cause any problems? I figured that erring on the side of a more powerful, thicker cable would be OK.
Thanks in advance for any advice you can offer.
