Hi all
I'm fiitting a new kitchen and thought I'd take the opportunity to move the cooker socket into a more practical position in the process.
Currently the cooker is wired to a plug which is plugged into the socket of a Cooker Control Unit. I have read that ideally the cooker should be wired to a Terminal Outlet Box which then goes to the Cooker Control Unit. Please see the diagram - this shows the wiring how it is now and what I propose to do. Is this correct?
Also, as you'll see from the diagram, there is another socket on the same circuit. However the new Control Unit I have only has supply in and cooker terminals...is it still possible to continue this circuit to the other socket?
Thanks for your time
Dan Hope
Dan Hope
