- Joined
- 4 Oct 2005
- Messages
- 555
- Reaction score
- 0
- Country
Called to a customer's house at the weekend (and missed the 1st half of the Argie game ). He had a pinhole leak on the cold water mains. On trying to cut-out a section of pipe to make a repair using a standard Kopex cutter I found the pipe was so thin it would crush as the cutter rotated. It seems the pipe has been disolved so that the wall thickness is only about 0.3mm (new it was 0.7mm). I have seen this effect close to brass fittings, but not about 3m from the stopcock as in this case. The customer reported that a repair had been made 6 months previously, this being a compression brass "repair" connector.
My questions are:-
What causes the pipe to be eroded in this way?
What can be done to prevent further erosion?
I checked the main equipotential earth bond at the gas meter and found this to be very loose in the connection. There was no other earth wire emerging from the main earth terminal, so I doubt if the water main is earthed.
The house is very large, consumer unit and gas meter in the detatched garage, plastic water service pipe rising in the main house 10m away.
I intend to replace the damaged section with plastic and renew the equipotential bond to the house (yes, I'm competant & qualified to do so), can anyone tell me if these actions will prevent further corrosion to the rest of the internal mains copper?
PS I wrote this after getting bored with the Switzerland/Ukraine match, tried painting the walls but that was only slightly more interesting than the match
My questions are:-
