The drop allowed depends on the gas meter, it`s certainly not 8mbar.
you reckon eh?
To be fair I couldn`t imagine any gas safe registered fitter leaving a house regardless of meter with an 8mbar drop without being a tad concerned.
There can only be one reason why you would even consider using his services further, he must be cheap, but dangerous, definitely incompetent.
So if it's in copper it's ok provided it's protected by a steel plate?
Is that both sides or just the one it's been chased into?
The recommended is vertical, therefore is horizontal a 'bit naughty but legal' or not to code?
but your not an gas safe registered "fitter" so you wouldn't know whats acceptable or why.
Sorry Mickyg, have I upset you in some way? Just trying to help, is all. I know that if he was fitting my gas I would be concerned.If any of advice is wrong or dangerous please I will apologise immediately.
I think he fitting the work in around other work as hes busy. Rushed the work and then taken a couple of goes to do it properly, as he should have done to start with.....
you haven't upset me but some of your advice is incorrect and misleading. If you don't know keep it shut rather than making it up.
I don't think there's actually any requirement to protect against damage due to nailing/drilling,
There is Muggles,if it`s buried in an internal wall, if it`s run in a plasterboard wall it`s also recommended that the pipe should be only run vertically.
It's a recommendation that the pipe only be run vertically regardless of the construction materials used in the wall
dont know whether these help or not....
To be fair as long as the pipework is sleeved through wall that looks o.k apart from the fact that it reduces to 15mm pipework almost immediately.Is this the main run to all gas appliances or does it branch off other side first in 22mm? Or is that 22mm? need me glasses.
Prove it, or apologise.
