Copper Pipe - for Cross Section.
  • Thread starter Thread starter kai
  • Start date Start date
K
kai
What is the cross section area of 15mm copper piping, i.e. the rising main from my water supply to my cold water tank?
I always wondered would it be be sufficient to comply with BS7671:2001 and its earthing requirements in a domestic home.
You CANNOT use a water pipe as a means of providing an earth to your installation.
it used to be allowed but the problem is that maintinace work can replace most of the water pipe with plasic liaving you with a very poor earth
I shall stick my neck out here and say that this is indeed true, but last appeared in the 14th Edition, which by memory, was issued the year I was born.
I stand corrected if I am wrong.
I was asking that because I was thinking whether I could run the bathroom supplementary bonding to the rising main, (as it is already main bonded at the incoming position), instead of a 25 metres long run of 4mm cable all the way back to the main fuse box.
You don't need to do either - there is no requirement to connect the supplementary bonding back to the CU or the MET.
