f49h said:All i am asking is the pipe to thin two bend or do I have to use elbows, that,s compression ones prof.
With an olive, ooh getting technical
and i could also use ptfe tape ( thats plastic tape for engineers!!) with them.
Well, lots of DIYers do, and what on earth is wrong with that?noonespecial said:You don't use compression fittings in lieu of getting the correct pipework for the job.![]()
Really? Why not? Perhaps you don't use it, but that doesn't make it wrong, so why do you imply that there is a general rule when there's no such thing? Perhaps to maintain some ridiculous clique of which you think you are a part?noonespecial said:...PTFEAnd you don't use that in compression joints
I disagree - the guy is willing to learn, has come to the right place (although receive many unhelpful replies), and, with some experimentation, there's no reason why he can't make a start. We all began somewhere...noonespecial said:I think you have too much to learn before you should attempt to install pipework.
ChrisR is right as ever. So? So if it's really 1.0mm wall thickness it will be to Table Y half-hard, and still be bendable. More likely is that the 1.0mm quoted by OP is an approximation. Here is the technical background stuff.ChrisR said:table X (now r250?) 15mm is 0.7mm and 22mm 0.9mm iirc, so...
Oy, enough with the jibes matey. You asked a technical question and got a technical answer. Leaving aside some of the more pompous posts on this topic, if you're in some way dissatisfied with the result then there's a technical action that you can take.f49h said:WhooooHooooo![]()
Cheers Chris for the answer, thats all I want to know.
Geezo it gets too technical in here.
Have to change the forum to,"look at me i am technical, forum"
I think I'll move to Cuba
