copper pipes under concrete
6 Nov 2008
Durham
Hi all,
I am moving a radiator from one end to another in the kitchen, I have removed the rad and placed a flexi pipe on the ends temporary until I can plan how to run the pipes.
Currently they are burried in concrete with bits of material round them. Doesn't look like a professional job really.
What pipe and protection is best do you think? Any ideas on good stuff to buy?
I have tried to avoid using Hep but maybe this is the way to go?
just read that I could lay 15mm plastic pipe and have a 10mm inside this. This sounds very fiddly.
Can I just use Hep and bury it in concrete or do I need a conduit to?
Trying to work out what to order!
Cut a channel in concete and fit your pipes inside plastic conduit or more expensively run plastic coated copper pipe in the channel but lay on a sand bed and cover with sand before screeding over
Hep is perfect for this job,make sure there are no joints apart from where they come out of the ground,I always use the felt lagging on them before burying in the screed,done many times with no problems
There is so much plastic pipe being buried now specially for underfloor heatits no problems at all ,the man who suggested plastic coated copper,have you seen the price of that stuff,you gotta to be off your rocka!!!! :D :D
Table Y copper is only suitable for below ground applications. There are reasons why it is expensive, worth the premium if it saves you digging up the floor again. Of course there are other ways round it. An option being to sleeve regular half hard lengths of copper in MDPE pipe.
Manipulative joints would be quite dear too :!:
