correct name for this pipe clamp?
15 Nov 2005
South
Cook Islands
some of my pipes are fitted using a brass clamp, where the bracket is screwed to the wall, and the bit that holds the pipe is screwed onto it with an adjustable stem. This allows you to adjust for spacing between wall and pipe. I have not seen these on sale, what is their correct name?
I want a couple to hold the pipes steady where I have fitted a Magnaclean for a relation.
school board clips or sb's,or you can make them with metal drop anchors/ m10rod/munsens rings
Gotcha!
Pack Size: Pack of 2
£5.62
that's the one except I need 22mm
there is a Wickes a short walk away, I will have alook
ta
thanks
I suppose theirs would be the "3/4 Black Iron Munson Ring x 10mm"?
also need a "Black Iron Female Backplate x 10mm"
can't see the stems though
will try locally first.
They say ""all orders with any amount of products have one single delivery charge of £5.00 + Vat".
Can't find it though :(
Where do I look?
Edited: Found it! In "Plumbing Fittings » Pipe Clips" :)
