Hi All
I am currently undertaking a major renovation of a 1920's bungalow, the wiring throughout the property will require replacement before we are finished but it is currently beyond affordability unfortunately.
I also need to replaster throughout which i plan to do by fixing tapered plasterboard direct to the walls/ceilings and drylining (I know skimming would be more straightforward but it is twice the price and I have had good results with dry lining in the past).
my questions are:
1. can I chase in and install trunking/conduit into the existing wall in preparation for new wiring at a later date? plasterboard would then be installed over the chase enclosing it into the wall.
2. If this is acceptable, is standard oval plastic trunking ok? for example this:
http://www.screwfix.com/p/tower-oval-conduit-16mm-x-2m-white/91802
3. do I need to cement the trunking into the chase or can I just fix using pins/screws and then board over?
many thanks for reading, any advice would be most gratefully received!
my questions are:
