What does the thermostat manufacturer say about it?What wire spec should I be using for wiring up a high and low pipe stat on a hot water tank?
No, you need heat-resistant sheathing.Do I need heat proof wire?
Yes.Guess it needs to be flex?
You will need some Amps.Amperage?
Are you saying that you have a choice of colour of conductor insulation?Colours?
Apologies - I should have been more specific. I meant to ask what the maximum currrent rating of the thermostat is. It will usually be 3 Amps.Wire spec.... The manufacturer of the stats says nowt about the wiring either on the box or in the instructions, hence my request for info here.
Then you have a choice:Colours..... Looks like I need four cores to the stats according to the wiring diagram... ?
1. You can go to a supplier and buy flex to the current colour coding standard.
2. You can find the old colour coded flex and use that.
.. whichever is the safer option. Safeness is determined by the risk of someone else becoming confused by the colours that you use. If the rest of your house is in one set of colours, then using a different set requires that you place a warning label in a prominent place, like on the consumer unit and on the heating wiring centre (often in the airing cupboard).
high stat to turn the pump off, low stat to turn it on..?
When installing the cable avoid having loops of loose cable which people might hang clothes on to air next to the warm tank.
