On some boilers you'd be risking a carbon monoxide poisioning if you did that. And you'd never guess why.
There's always more to anything than there looks at first.
For futue reference its safer to shut off the boiler isolation valves and leave off for 24hrs. If pressure drops leak is in boiler, if no pressure drop its on the pipework/system
Tony, in that case you will have no problem answering following questions.
1) What is the noticeable (manufacturing) difference between Flowmatic, Excell and Linea 24/ 28 main heat exchangers (termistor tapping apart on the Linea)
2) After the HE has been replaced, is there any problem or difficulty replacing remaining components on above boilers models and if yes, what is it?
3) Which of the two Flowmatic or Excel HE tappings is slightly angled
I dont remember that much detail about the ones I change and certainly dont place different models side by side to compare them. I may be a boiler anorack but not that much!
I dont think I have changed the HEs on any of those models. It seems to be mostly the heat only models I go to but that is probably only by chance.
Do you have any idea why Voka HEs seem so likely to leak? Like the OPs, I think all of mine have been the right hand side too!
I dont see any particular difficulty putting the boilers together as long as i have my long reach PD2 and have magnetised it recently.
I think that I have changed four Voka heat only boiler main HEs. Odd you have also found that type to be the ones that fail most. There must be a reason as there is only one heat only for about 25 combis.
I can only remember changing three leaking low water content main HEs on other combi makes.
