Cost of a suspended timber floor (ground floor)
1 Jul 2004
London (North)
We've had to completely remove and throw out what was currently in place on the ground floor. Due to venting, we need to put in a suspended timber floor.
Could anyone please advise how much I should expect to pay per m2 for a suspended timber floor, with chicken wire holding rockwool insulation and with a chipboard finish?
Really appreciate it
What sort of info?
Its a semi in london
The floor is now mud, the old floor has completely been ripped out.
Floor height is about 400mm above soil level. That might be wrong.
Why a suspended timber floor? 400mm is ideal space to incorporate an insulated concrete floor and screed.
100mm stone.
50mm sand blinding layer.
DPM.
100mm concrete slab.
75mm foam board insulation.
75mm screed.
Alternatively you could position the insulation below the floor slab and have a thicker stone layer or a thicker concrete layer and have a power-floated slab whilst losing the screed layer altogether.
chipboard is certainly cheap, in every sense, but does not last well. I'm replacing mine with WBP ply as and when the rooms are redecorated/or new carpet fitted/or the number of cracks and breaks in the chipboard enrages me/or I can be bothered.
I would never inflict chipboard on myself.
It is a semi that is virtually a terrace, there is absolutely no side access. There is barely a front garden.
The floor was rotten, outside the scope of works, and has got to be changed pronto as it's holding up the build. The ground floor bathroom needs to go in before Christmas.
Chipboard, whilst cheap and squeaks aside, really is inappropriate for bathrooms or kitchens. Even moisture resistant isn't very good. Any sustained damp leaking into the floor will make it swell and replacement is the only fix. And if its beneath the kitchen units ......
What do you suggest instead?
Plywood is a much better choice, it doesn't swell when wet, so can be dried out and does not need to be replaced should something happen, we understand you're on a budget, the forum is littered with people asking how to replace chipboard floors. Sorry can't comment on prices but overall there won't be much difference. As ever three quotes will get you an accurate price.
