ours has a drying cycleThat is very different to my result, when I checked mine - you have a short time of heating at the beginning, then a much longer time of water heating long after the wash was completed. Why would it do that?
that looks to be around ¾KWh to me
I doubt it. If I recall correctly, there was a time when most machines had dual (H&C) feeds, to the extent that whenever I installed plumbing provision for WMs and DWMs I always installed both. However, I don't recall ever having seen a 'hot only' one.I had a WM once with H&C feeds. Does anybody make appliances which only have a hot feed?
I guess I have to blame the effects of old age on my memoryEvery couple of years we have this discussion lol
I can perhaps understand for the very old one, and even 1012 is pretty old, but these days people seem to expect (some are 'obsessed with'I have a very old dishwasher that is designed for hot feed only. .... And a more modern 2012 Bosch that is hot feed only.
Yes the heater back on, why pulsed? Washing again
seems second lot of hot water.
still not finished, what is it doing using only 3 watt?
finished. So used a little more today, it was 1.08 kWh last time.ours has a drying cycle
once during a heavy cold , before opening the door I remembered all that awaiting steam, I also remembered breathing warm damp air is good for colds, so I opened the door and took a deep breath - all those cleaning chemicals breathed deeply in, nearly knocked me out.... never had a cold sinceSo does ours. If you open it during the drying cycle, your face is met by a lot of hot steam, no sign of water at the bottom.
