ok thanks guys guess ill geta few more quotes if the price is still on the high side ill fit it myself cant c it taking more than 2 hours.
thanks again
if you don't give each quoter the exact same brief, then they will probably come up with their own conclusions..
one may be quoting for a standard split load board with one RCD, whereas the other may be quoting for a dual RCD split load board to comply with the incomming regs.. (yes I know we can work to them now, but the old regs are still acceptible until june aren't they? )
one may not have looked to see if the main bonding is up to scratch, and will either try to stiff you with that as an extra or will absorb the cost themselves..
one may have looked in your board and seen doubled up circuits and want to split them into a larger board..
one may be intending to fit RCBO's to several circuits to conform to the new regs..
if you have the quotes in wrighting, make sure that they detail exactly what they are covering..
thanks again
No offence but i dont think you know what it involes.....
its not a case of just screwing it to the wall. Thats why were professionals and do things properly so if you have a fault with your cooker you want the fuse to blow before the cooker does.
