B
BigBurner
Should find some articles in trade publications .
That is the place for info, not from bathroom changers.
Thanks BigBurner, I like the sound of that "Willo Smart pump" But is this it...?
You've described the kind of plan I had in mind, although I'm a bit concerned about how the boiler will cope the instant the pump stops circulating? OK, the flow switch cuts the burner at the same time, but there was a reason for having pump overrun and that seems to have been eliminated.
OK, Screwfix miss a trick with the way its described then - looking at it it just looks like a manual three-speed job (so why is there a three-pos. switch if it's got automatic speed selection?)Thanks BigBurner, I like the sound of that "Willo Smart pump" But is this it...?
Yes. Gundfos do the Alpha version, but costs much more.
The boiler is a Glow Worm Flexicom 30HX with open vent. The pump is located remotely from the boiler.What boiler do you have?
Does it have an integral pump?
Is the system a sealed system? Or open vented?
It's getting a bit complicated now! I guess the smart pump wouldn't work very well with an automatic bypass.Just musing:
If pump overrun is essential on your boiler and it is a system boiler (integral pump), then a plate heat exchanger can be fitted just after the boiler to isolate it from the CH/DHW side.
Plate is around £90-100
Smart pump £47
flow switch £20-25
New TRV valve £10-15
Make sure plate is well insulated.
Smart pump £47
flow switch £20-25
And what would be the labour to fit this and is it a valid and proven configuration? - I need to reduce our heating bill. We have one radiator in the airing cupboard without a TRV that runs all the time. I have turned down the lockshield but it is a constant pull on the boiler and the wallet as well.
Cheers
Steve
Steve
Can't , well I can, but this is supposedly for the system feed - top radiator or whatever.
Steve
If rooms are heating up a widely differing rates, that would suggest that the radiators have not been sized to match the heat loss of the room.... it would seem to be necessary to identify the last room to reach it's desired comfort temperature before the stat is fitted in that room.
Steve
System feed? What do you mean?
they like expensive top of the range engineering and they are willing to pay for it
To Vex!
Whilst its easy to have ideas, its very difficult to come up with ideas that have not been considered before and either developed or found to be of no or little advantage.
You have been advised of a boiler which turns off if there is no flow round the system because all the TRVs have closed. Its not that wonderful because the pump has to be turned on every 5-10 minutes to see if any TRVs have opened since it last checked.
