While trying to figure out the cause of my central heating woes I'm wondering if there's a useful improvement that could be made to the current type of system:
Having TRV's is clearly a good idea: All radiators should have them fitted to allow individual rooms to be set to a preferred temperature. But something needs to tell the boiler whether or not there's a demand for heat. Traditionally this is done with one or more room-stats.
In the UK, Eaga (the independent Partnership Charitable Trust for the promotion of energy efficiency) advise having no TRV in the room with the overall thermostatic control. This room then dictates the boiler demand. With this setup, this room may then have to be run at a higher temperature than is desirable in order to keep sufficient heat to meet the demand in other rooms. In my own case the thermostat controlling the boiler is in a large hallway that extends all the way up to the V of the roof. Naturally the radiator in this hallway just sends heat up to the top where it gathers in great quantity!
So, when all the TRV's close, this unregulated radiator in the hallway is all the pump/boiler has to feed and I can almost sense the "tension" building up before the room-stat trips. But this got me thinking: the signal that the boiler is no longer required could be that *all* the TRVs have closed...
...So if the pressure in the system (or would it be flow rate?) is set to cut the boiler in/out at a certain threshold, then *all* rads can have TRV's and the boler is only called on when one or more TRVs requires it. Perhaps I'm talking nonsense, perhaps this has already been done (where can I buy one?) or perhaps it will make me rich
Er, perhaps not now I've mentioned it [/i]
