I forgot to mention winston1 will offer a comment which can be totally ignored
Additionally lighting circuits can be rings, again there is no restriction and they are sometimes wired that way.
What was the ring circuit designed for then?I've told you before. DO NOT tell people to ignore other members.
The ring circuit was never designed or required for lighting circuits. Just because you found one does not make it right.
Neither is it wrong nor the only lighting ring I've worked on.The ring circuit was never designed or required for lighting circuits. Just because you found one does not make it right.
Better to fit a 5 amp socket and change the plug on the camera
I did and it isn't. Had you read all the thread especially post number 3 you would know that.That is a possible solution to preventing overload but first make sure the 13 Amp plug is not a compact power supply unit.
That is not the same as telling people to ignore people that are factually right.Sunray is right to advise people that some comments / information posted on this forum may be factually wrong.
Don't offer incorrect advice and we will not need to contradict you.
There are reasons why some lighting installations should be wired as a ring final.
I do know the history of the ring circuit but from your frequent posts on the matter it is quite apparent that you don't. The correct information doesn't seem to appear in this forum so I'll ask you, winston1, again what you think the ring was designed for?As a long standing Sparks I am surprised that you don't know that. Search these forums and you will find the answer.
Oh I see now, you think you can correct posters and tell them to ignore others when you think you're right.That is not the same as telling people to ignore people that are factually right.
Do you really test circuits with a 10 quid Lidl multimeterWhat not even this one?
It's part of my arsenal of test kit. Anything serious is done with Kew or Robin.Heres one I took earlierView media item 22107Do you really test circuits with a 10 quid Lidl multimeter
You have the freedom to disagree, but consider the possibility that the people you disagree with may be far more experienced and knowledgeable than you are.I disagree.
