Counting
9 Nov 2009
Edinburgh
Ok, long shot, and perhaps I'm being a bit thick ...
Client wants a meter on a mains circuit to count how many times it's been turned on. Not run time, but number of times it's been turned on.
Anyone know of such a device available off the shelf?
eBay item number 380332712599 plus a 12VDC power supply would do it.
You're looking for an impulse counter.
Any clock and multiply the result by 100. OK I know going a bit silly but any unit must have some time delay. So it must be mains failure over X cycles long. The simple impulse counter will count and size of capacitor in the power supply will determine how long power has to be off before another failure is recorded. So yes reason for wanting it does matter.
Supply is always on, but it's push button operated and switches 240Vac so easy enough to splice into
That makes sense the required delay would depend on what you're actually trying to detect. Would using a simple counter with a capacitor-based delay be reliable enough for your application?
I imagine that in the more than 10 years since the OP asked he has either found a solution or long since given up.
