- Joined
- 29 Oct 2004
- Messages
- 57
- Reaction score
- 0
- Country
Have sorted out some very bad wiring in the bedroom - a spur on a spur, using bell wire, among other things...anyway, I've added these onto the ring now. Trouble is, I'm replacing singles to doubles. I have 2 issues.
1 - Two of the sockets are on a party wall, and seem to be not made of brick or breeze block, more like a concrete material. I've attempted to knock holes in/drill to make the hole bigger but it's just solid. The original single socket was in a 16mm box. Is it possible to get a double box which is 16mm deep. The actual hole is more than 16mm deep, it's more like 20mm. If that's not do-able can I put 2 16mm singles together?
2 - The other issue is the plasterboard walls. They aren't quite stud, they are made of a cardboard mesh sandwiched together between plasterboard. I hate the stuff! Anyone had any experience with them? The trouble is you can't use the usual dry-lining boxes because the cardboard gets in the way. Can you use metal boxes no-nailed in the holes?
